Unknown format error reading PDF file
Big Ern
Post by Big Ern »
I'm trying to read a PDF with GFL SDK and getting an “Unknown format” error. I’ve read your answer to the “Converting PDF files with GFLAx” posting, and I’ve set .EpsDpi = 72, as you suggested. It didn’t help. I’m programming in VB 6.0.
Re: Unknown format error reading PDF file
Big Ern wrote:I'm trying to read a PDF with GFL SDK and getting an “Unknown format” error. I’ve read your answer to the “Converting PDF files with GFLAx” posting, and I’ve set .EpsDpi = 72, as you suggested. It didn’t help. I’m programming in VB 6.0.
You must install ghostscript.
