Hi there,
is it correct that the color ratings and color tags are shown only in the folder where they have been assigned? I rated a picture and then moved it to another folder. In the new folder none of the ratings are visible, but when i move the picture back to the original folder all color tags/ratings are shown again.
Birdman
Ratings are visible only in folder assigned?
Re: Ratings are visible only in folder assigned?
When you copy/move file, i don't copy rating/color informationBirdman wrote:Hi there,
nightflyer
Birdman
I agree. It would make no sense at all to use the rating information if it will not be copied inside XnView. If a picture/file is rated as an excellent one it will stay this regardless in which folder it is placed.nightflyer wrote:Info should be assigned to file and moved with file.
Of course if someone moves file outside of XnView the info can't be updated, but otherwise it should.
OkBirdman wrote:I agree. It would make no sense at all to use the rating information if it will not be copied inside XnView. If a picture/file is rated as an excellent one it will stay this regardless in which folder it is placed.nightflyer wrote:Info should be assigned to file and moved with file.
Birdman
Sorry currently with RC, i don't add/change new feature...Birdman wrote:Great!xnview wrote:Ok![]()
By the way, if you need to make a change because of the ratings anyway, would it be possible to make the ratings searchable? It would be a nice feature if one could search for all excellently rated pictures for example.
Birdman
