rc1: Icon for delete?
surfacecleanerz
Post by surfacecleanerz »
Is it possible, to add an icon (recycle bin) for deleting an picture in view mode per mouse without richtclicking and searching for the right line?
It would be great (and no big thing, I think)
Stefan
Last edited by surfacecleanerz on Tue Jan 16, 2007 7:26 pm, edited 1 time in total.
Re: rc1: Icon for delete?
surfacecleanerz wrote:Hi,
Is it possible, to add an icon (recycle bin) for deleting an picture in browser mode per mouse without richtclicking and searching for the right line?
Stefan
Sorry but now i can't change such things...
surfacecleanerz
ok
Troken
Post by Troken »
But there is a delete button. In the top row of the thumbnails window you'll find a red "X", which is "delete". I suspect Pierre meant that it's too late to change icon at this stage, but it do exists. :wink:
surfacecleanerz
it's a real problem if one is typing other things, than that one means.
I corrected it above: I meant view mode, of course!
Sorry,
Stefan
Troken
Post by Troken »
surfacecleanerz wrote:it's a real problem if one is typing other things, than that one means.
Ha ha, yes thats a problem of course. :)
Actually, you can add a button yourself. Go to "Options" -> "Toolbar -> "Buttons"
Select the button "View" and then click "append". Now you got a new button (looks like a thin line until you pick an icon of your choise), give it a command (i.e. "delete") and a nice icon. You can also put the button where you want it in the row with the two arrows.
Voila. I've added my favourit feature "export" this way.
surfacecleanerz
You're right!
Big Thx for the tip!
To be closed!
Stefan
