If I create a new sub folder e.g. of my files, it jumps, after typing the name, not to this new subfolder name, but to the name of the subfolder marked before.
I think this behaviour is incorrect, or am I wrong and its an feature, I do not understand?
Stefan
V 1.90 RC2
after adding new folder (browser), jump to last folder
surfacecleanerz
Re: rc2: after adding new folder (browser), jump to last fol
Can't reproduce it, could you tell me how to reproduce it?surfacecleanerz wrote:Hello,
surfacecleanerz
of course I can:
In browser mode: click on an folder (here called a), then right click on an other directory of your choice (here called b), select new folder (to create a new subfolder of b), type in a name for it (e.g. "b") and press Enter =>you are not in b, but in a. Then you have to search for b, because after creating a folder, it is normal to go to that folder in order to put files into or something like that, I think!
Stefan
of course I can:
Stefan
Ok, so for me it's the normal behaviour, but perhaps not for all userssurfacecleanerz wrote:Hello,
of course I can:
Stefan
surfacecleanerz
Olivier_G
It is the normal behaviour (the current selected folder was and still is 'a').xnview wrote:Ok, so for me it's the normal behaviour, but perhaps not for all userssurfacecleanerz wrote:In browser mode: click on an folder (here called a), then right click on an other directory of your choice (here called b), select new folder (to create a new subfolder of b), type in a name for it (e.g. "c") and press Enter =>you are not in c, but in a.
It is especially convenient if you want to move files of the current folder into a new folder: no need to move back and scroll twice through folders...
=> not a bug and I wouldn't even support this as an option.
Olivier
surfacecleanerz
Olivier_G
surfacecleanerz
Dreamer
