¡overwrites the previous INI !
:) Hello !
• For some reasons I know partially (hum… I suppose…) when RC1 is started,
almost all settings of the previous INI are reset to default…:shock:
- So, I'd to remake my configuration (pretty customized) using some parts I had in a back-up from ß-6… :(
• Especially, all ColorFilter0n=… are removed (for the font colours by file-type in Browser >> Detail view),
only the old BColorFilters0n=… remain (or are reset).
:mrgreen: KR
V 1.90 RC1
Re: ¡ RC1 overwrites the previous INI !
Clo wrote::) Hello !
only the old BColorFilters0n=… remains (or are reset).
:mrgreen: KR
Perhaps you had xnview.ini in document setting???
Programme directory
:) Good morning,
• Nope ! In the programme directory ! It has been killed there !
:mrgreen: KR
Re: Programme directory
Clo wrote::) Good morning,
:mrgreen: KR
Strange i have no problem
Too zealous
:? I guess that there was a hitch when updating the INI about the obstinate entries
which came back endlessly for the Colour Labels and so…
• At the first start up, indeed these entries have been removed - so now the translation works - but alas, all other settings which had nothing to do with that have been reset to default,
and like I said above, all the ColorFilter… entries (for fonts) too…
• Nothing has been created in the <user> folder, this is really the current INI which has been changed.
- I never saw such an issue before, while I upgrade always by hand, and keep the current INI.
- XP-Pro SP1
:mrgreen: KR
