RC1:Some file type can not be opened
sergo
Post by sergo »
I've found some old images of RLA and RPF types which are opened by xnview 1.82 without any problem, but new RC1 can not open all of them. Only 32 bit images are opening, not 64-floating point.
I've send these images to you. Not tested with betas.
One remark - xnview 1.82 has standard plugins installed separetly. May be the problem is there.
Re: RC1:Some file type can not be opened
sergo wrote:I've found some old images of RLA and RPF types which are opened by xnview 1.82 without any problem, but new RC1 can not open all of them. Only 32 bit images are opening, not 64-floating point.
One remark - xnview 1.82 has plugins installed separetly. May be the problem is there.
Not received :-)
sergo
Post by sergo »
Just sent, will be in minutes - 4 big file:)
sergo wrote:Just sent, will be in minutes - 4 big file:)
It's good :-)
This bug is supposed to be fixed in XnView 1.90 final.
sergo, could you please verify this bug fix? (If I had RLA and RPF files I would do resting myself, but I haven't any).
