Settings dialog leaves checkbox unchecked when viewed again. Unchecked should revert settings back to default size does not. Could you 'retain perspective' too, so that user does not have to study correct perspectives on setting the slider. Suggest one slider only.
XnView 1.90 <x>
Use huge thumbnails - unexpected performance
Alistair George
Alistair Grant George
Olivier_G
Re: Use huge thumbnails - unexpected performance
I explained here why 'Use huge thumbnails' shouldn't revert back. So I support this.Alistair George wrote:Settings dialog leaves checkbox unchecked when viewed again.
Olivier
