Already needed : A “Commands Manager”…
Group for those who want to contribute in the area of translation of On-Screen texts or Online help of XnView Classic
The French Topic - L'article en Français —>
:) Hello All
• Trying to lighten the Pierre's tasks for the future languages text-files,
and to improve already the features of the programme,
I propose a Manager dialogue-box which could ease the customization of the settings :
——————Image
- Indeed, only for the extra-buttons of the tool bar now.
- However, it might be much handier than the current drop-down list¦s…
- On the model above, one can see that some descriptions are truncated, even almost missing.
- This is like they are displayed on that list, and I didn't patch them voluntarily to show the issue…
- Personally, I guess that the square brackets are useless with such a display…
- I drew also a few grid-lines, to get your opinions about this.
I'ld be rather in favour, because it's easier to spot all items for the row of a command.
• This box could be opened as a non-modal window -like we have now in Total Commander-
and is designed to satisfy the specific needs of XnView, naturally.
• As a first step, that box could be opened from a small Image button set beside the Command caption
(there is room enough) in the tool-bar Options page.
- From this, the radio-button “Tool-bar” should be automatically already enabled, of course.
- Also, the appropriate “Mode” button gets the focus.
- Then, when the command is chosen, the “OK” button should add the command in the Options and close the box.
• For later, the box being invoked via a special command (in a menu or so…), the user could choose which mode s¦he wishes
as allowed commands to be displayed.
- Also, tick the “Menus” radio-button and get a menu-bar-like (greyed out on the image). Of course, each menu shown should be the one of the mode chosen with a Mode button.
- The list of the normal plus possible commands for each pop-up of the clicked “Menu” should be displayed in the first column.
• Currently, there is a huge ? in the second column for the commands numbers.
- I could find them for the example, but unfortunately, some are changed along the versions,
and this is not desirable when using menus as text-files. The commands numbering must be absolutely stable !
- Since the menus in XnView are written using only a command-number, thus this number could be copied into the Clipboard
from a button, in order to use it elsewhere, i.e. while changing a menu in an editor.
• For the menus, this tool could be enhanced (edit¦change a menu directly), but it's soon too much to discuss this…
- What do you think ?
:mrgreen: Kind regards,
ouistiti
Post by ouistiti »
:arrow: Clo
I guess that a tool is already useful and shall be indispensable later, so I support that proposal !
-This list is not handy, that's true, all is shown messy…
…The commands numbering must be absolutely stable ! …
- This is a basic criterion! Moreover, all commands must be known and listed in a text file i.e. «xnv_commands.inc», this allows to get translations for the comments directly, like in TC now !
Friendly
Paul
1,77245385090552...
Brother Gabriel-Marie
Post by Brother Gabriel-Marie »
Let me add a new post to let everyone know that this idea of the Commands manager simply is a MUST. Anybody who needs/likes/wants to customize their program can do it like nobody's business. I suggest you to take the trial of Total Commander and see how you can apply literally ANY command to ANY button! POWERFUL!
Of course, XnView will have to be made to work out the problem of the three view settings - like Mr. Claude's three Command lists.
So, there you have it, a fresh vote from an XnView lover and devotee.
-Brother Gabriel-Marie
Thanks !
:arrow: Brother Gabriel-Marie
:) Dear Brother,
• Thank you to support that project (it's more than a suggestion, IMHO), it could be more largely discussed and improved.
• The mock-up is indeed quite incomplete for some reasons you know…
- It might include a section to customize the keyboard short cuts too, a leitmotiv which comes back often in that forum.
- Actually, that's the same problem :
¤ Buttons, menus and short cuts are the three spokes of the same “Internal Commands” wheel
and might be treated together¦jointly (see the Paul and I's avatars… ;) )…
:mrgreen: KR
oops66
Plus custom hotkeys setting
Post by oops66 »
Clo wrote:...
- It might include a section to customize the keyboard short cuts too...
It's a good idea to include a column for custom keyboard short cuts (and to reset :a button "XnView default hotkeys" setting) , I support this improvement too.
XnViewMP Linux X64 - Debian - X64
3-tab page…
:arrow: oops66
:) Hello !
• Thank you to support this important project !
• In fact, I plan to update the mock-up as a page with i.e. three tabs - instead of radio-buttons-,
so a page from a tab for the short cuts… :wink:
• I'll change the image and draw the complements a.s.a.p.… hoping I'll find time enough !
• An active list (like in the Options) should be nice too, it could bring more resources, especially for the menus…
… but need more pages then.
:mrgreen:
oops66
Re: 3-tab page…
Post by oops66 »
Clo wrote:... I plan to update the mock-up as a page with i.e. three tabs - instead of radio-buttons-, ...
Good idea Clo, I prefer the tabs concept too.
New mock-ups
:arrow: All
:) Hello !
• I drew a new version of that project, the mock-ups are shown below :
• The design is not indeed perfect, it's just to show some ideas and get the users' feed-back…
• Of course, the Menus page is not relevant yet here, since it needs menus as text
(and it's only to find¦copy the commands easily, not as a menu editor which could be another step).
:mrgreen: KR
oops66
Re: New mock-ups
Post by oops66 »
Very good Clo,
Or maybe something likes in digikam ???
Post by Guest »
Hey, this all looks very promising. Clo, I wasn't thinking of anything so grand, however. If you look in the options for the customizing toolbars, you already have the menus for adding commands in the three different views. I think your new menus look a lot better, and would be more user friendly, but how hard would it be to just list the extra commands in the command chooser already built into XnView? Already you have to choose "browser" or "view", etc. to decide which commands are going to be added. I don't see anything more involving for a 1.95.1 (or 2) edition than adding the commands *already in the programming code* to the command listings.
A base for more…
:arrow: Guest
:) Hello !
• Like you can see on the first approach in the start message above, the drop-down lists are a pain in the neck,
it's hard to find out and choose a command, some strings are truncated etc.
• In Total Commander - where the commands are organized differently - we got a Command Browser instead of an awful list,
that made all users happy !
• I designed this project as a base for an enhanced use later, since in theory we might get languages
(strings & menus) as text in XnView 2.0…
• Other GUI items could be customized from there, I planned a "Provision" for a few ones…
• The current buttons configuration box is not too bad, despite that some lacunaæ must be filled in…
Pierre has reports about this.
- Hence, I don't wish a merging of the configuration with the command choice, except maybe for the short-cuts,
since it needs all commands and doesn't exist at all till today…
• Currently, such a tool could start for the commands used by buttons, so the base should be done…
Begun is half-ended“ (French proverb :D)
• An important - but simple- step is to get the commands as text-files, let's say *.INC,
one per view mode and one with the whole (short cuts).
:mrgreen: KR
Dear Clo,
This is all quite wonderful just to imagine! It seems like XnView has some competition from FastStone... but a command browser for XnView just might keep back the swelling. When could we expect to see this (God bless you) in the new version of XnView?
P.S. I was the "guest" who forgot to log in above.
Um, is it possible to get an alpha version so I can help with testing and suggestions?
Just a---
:) Dear Brother,
• My apologies for the late answer, and thank you again for the support.
• Unfortunately, as long as we will not see any feed-back from the Author in that thread,
no hope to get any alpha-ß version of anything, all that it contains will remain a wishful thinking… :|
:mrgreen: KR
