Custom selection ratio, inverted
Drahken
Post by Drahken »
I'm certain i saw this mentioned somewhere before, but now i can't find it. Make a rectangular selection, set as custom ratio, hit C to use the custom ratio. The proportions will be inverted (ie, if it was tall and skinny, it's nowshort and wide). This bug has existed for a while (maybe since the beginning?), and still exists in RC2. Since I never used it very much and since I had seen it posted, I never bothered mentioning it. However, I have been using it quite often in trying to make widescreen wallpapers, so I thought I'd bring it to pierre's attention again in case he forgot, or didn't notice the previous thread.
It's not a high priority bug, especially since hitting TAB will switch it to how it's supposed to be, but it does get annoying.
marsh
Post by marsh »
Confirmed.
marsh
Post by marsh »
Fixed. RC3
