When I dbl click an image from Explorer I get a 2nd copy of XnView with a single tab in it. I can't figure out how to get the 2nd image to open as a new tab in the instance of XnView that's already open. I've tried with the 'Only one view opened' enabled and disabled but the behavior is the same.
Any ideas?
Using v. 1.82.4 on a fresh install of XP Pro.
Forcing images to use tabs in single instance of XNView
pqee
Drahken
