RC2: Thumbnails aren't created when starting from shell
iycgtptyarvg
Post by iycgtptyarvg »
When starting XnView by double-clicking a picture in Windows Explorer, no thumbnails are created for the initial directory when in browser mode.
1. Double-click a picture in Windows Explorer.
2. You are now in full screen mode. Press <ESC>.
3. You are now in browser mode. Note that no thumbnails are generated for the other pictures in the directory.
PS
This is reproducable in both RCs and the betas.
Configure…
:) Hello !
• This doesn't occur here, it works and always worked as it should…
1. Why do you start in Full Screen ?
2. You have to set the displayed items in the Options >> Browser >> File list.
3. Also, check the Options page Browser >> Thumb nails, i.e. to display the 4-in-one thumb nails on the folders…
:mrgreen: Kind regards,
marsh
Post by marsh »
iycgtptyarvg wrote:When starting XnView by double-clicking a picture in Windows Explorer, no thumbnails are created for the initial directory when in browser mode.
PS
Confirmed. The following settings must also be used:
Mode when starting a file= Fullscreen-Browser.
[ ]Single ESC to exit (on start only) off
iycgtptyarvg
Re: Configure…
Clo wrote:1. Why do you start in Full Screen ?
Because I want to view the picture!
Clo wrote:2. You have to set the displayed items in the Options >> Browser >> File list.
I have done that.
Clo wrote:3. Also, check the Options page Browser >> Thumb nails, i.e. to display the 4-in-one thumb nails on the folders…
I have this option disabled (I don't show sub-dirs in the browser anyway, just pictures. I use the folder tree to navigate).
marsh
Post by marsh »
Fixed. RC3
