RC2: No separators in default skins
In the default skins provided with RC2 there are no separators.
In XnView 1.82.4 we still had separators which had grouped the symbols into logical units. In 1.90 RC2 there aren't any separators in the main toolbar (in the small toolbar there are).
I'd like to see the same separators as in 1.82.4.
Re: RC2: No separators in default skins
helmut wrote:In the default skins provided with RC2 there are no separators.
Right, i'll fix...
Optional
:arrow: Pierre
:) Good evening,
• Please, could you make this optional in the INI ?
- The wide separators waste room too much for me, and I don't care to get groups of icons like formerly.
In View, I'ld miss several useful icons…
- Anyway, a separator item could be set at will from the tool-bars configuration later, but only as a narrow vertical bar…
- TIA to consider this.
:mrgreen: KR
ouistiti
Post by ouistiti »
:arrow: Clo
I support in the ini or in a dialogue box !
Friendly
Paul
1,77245385090552...
Clo wrote:• Please, could you make this optional in the INI ?
Couldn't you simply delete the separators in Options > Interface > Toolbar?
Which item ?
:) Again…
• Yes, but there is not such an item currently ! And we don't know which stuff Pierre'll use…
- This needs to get a visible identified item…
:mrgreen: G.
Right, you can only delete something if there is something visual to delete. From what I can see there are separators available when customizing the toolbar (e.g. when adding a button).
Edit:
When using "Reset all" seperators are shown. So I assume that removing and adding is possible.
@Pierre: Do you confirm that the default separators will be visible and deletable in the options?
Verified fixed in RC3. Thank you, Pierre.
Note:
The separators are shown in the options and can be removed manually.
