RC2: 'Remove from category' not greyed out
Currently, the menu item "Remove from category" is always active. I think that it should be active when a category is selected, only.
Re: RC2: 'Remove from category' not greyed out
I don't understand, you have it after you have selected a category...helmut wrote:Currently, the menu item "Remove from category" is always active. I think that it should be active when a category is selected, only.
marsh
