After I do a search in folders (and its subfolders) and click the "Browse" button to see the thumbnails of the results of that search I have the following problems:
- Statusbar is not correctly updated when selecting the thumbnails, some panels in the statubar doesn't have their content changed (showing old information)
- Selected thumbnail is not shown on the second monitor when using the fullscreen to second monitor (middle click on the thumbnail)
I'm also having few redrawing problem after exiting fullscreen view. My taskbar doesn't get repainted, so parts of the image that I was seeing in fullscreen are "painted" on my taskbar and I need to force redraw of the taskbar by moving it around.
EDIT:
I'm having problems with Preview panel too, it does show the preview and also doesn't show tabs (Properties, histogram, ...) sometimes. It also doesn't get updated when I switch thumbnails.
The statubar problem is also happening with "Show files in subfolders" enabled.
V 1.90 RC2
Problems when browsing Search results
Re: RC2: Problems when browsing Search results
Very strange, i can't reproduce this problem. You have this problem always? Send me your .ini file to check...chronon wrote:Hi,
EDIT:
chronon
I can't reproduce the statusbar problem anymore...but the problems with preview and second monitor fullscreen are still there
Here is my ini file: http://www.mytempdir.com/1190394
sérgio
And if you don't use second monitor?chronon wrote:I can't reproduce the statusbar problem anymore...but the problems with preview and second monitor fullscreen are still there
chronon
And if you use F11 on a picture? And use mouse wheel? Even with RC3?chronon wrote:If I middle click an image without using the second monitor the same problem happens: if I roll the mouse wheel (or page up/down) to show another image the screen goes black and I need to exit fullscreen by pressing ESC.
And on folder, you have no problems, only on search results?
chronon
The screen goes black after I try to switch to another image in fullscreen, doesn't matter if it is search result or not, or if I use mouse wheel or F11
EDIT: Previous test was using RC3. Anyway, I think I found the problem, while updating between RC's I didn't update the .ini (to keep my settings), when I removed the current .ini file and created a new one everything started to work again...
sérgio
And your old .ini is http://www.mytempdir.com/1190394?chronon wrote:The screen goes black after I try to switch to another image in fullscreen, doesn't matter if it is search result or not, or if I use mouse wheel or F11
chronon
I'm so sorry, I wasted your time!
But disabling that option also disable full screen navigation (doesn't matter if it's in the primary monitor or the secondary one), which is not a preview since you are visualizing the image in full screen instead of using the viewer. So, I think that disabling that option should not disable the full screen features, unless you want to preview to full screen, which was not my case, I think...
sérgio
