Sort Order different then Explorer
imforumman
Post by imforumman »
The sort order of the files in XnView is different from that used by the Windows Explorer. This is kind of annoying... here an example:
Windows:
XnView:
Possibly XnView sorts by whole filename and finds that a "-" comes before ".", whereas the Explorer sorts by filename without extension and finds that "IMG_6534" comes before the longer "IMG_6534-psp" and only then sorts identical filenames by extension.
I think it would make sense to follow the MS-imposed standard, just so that a files are sorted the same in all programs.
Thanks... and BTW, 1.9 RC2 is looking good!
Re: Sort Order different then Explorer
imforumman wrote: I think it would make sense to follow the MS-imposed standard, just so that a files are sorted the same in all programs.
Right...
imforumman
Fixed.
Thank you!
