performance: Whats the fastest way to resize and resample?
daniel
Post by daniel »
Hello again,
i'm testing XnView, GD lib (PHP bundle) and ImageMagick. Due to the large file format compatibility of XnView and ImageMagick i'm doing some benchmarks on them.
I found out that XnView ist much faster in average but has a lost in color acurancy. But this is not the point.
I was wondering, if I could speed things up by using the -rtype quick flag when resizing. It turned out to be even much slower.
My aim is just creating really (and i mean really) fast thumbnails (well, width of 400px) where quality is not very important.
I'm having JPEGs of any size going up to 30MB, which takes far more than 60secs (my limiter).
Now i'm using:
I've tried:
nconvert -out png -o output_image.png -ratio -rtype quick -resize 400 0 input_image.jpg
which is even slower.
Any idea how to speed things up?
Windows XP Pro SP2 | XnView 1.82.4 | GhostScript gs854w32
Re: performance: Whats the fastest way to resize and resampl
daniel wrote: Now i'm using:
I've tried:
Strange that quick is slower, but the process can be quicker if i add a thumb_size as option. For jpeg it is better to load on the fly a reduced picture (as xnview).
daniel
Post by daniel »
How does that work?
Do I add -thumb_size to my command? I couldn't find the thumb_size as a parameter listed with the -help flag. Where do I put it? Is this documented anywhere?
daniel wrote:How does that work?
No i means if i add this command... Currently there is no such option...
daniel
Post by daniel »
ah, i understand :)
well would definetly be nice to have. Due to your fast resizing capabilities nconvert might have a big future in the web server business. If you get the last edge of performance out of it, especially concerning thumbnails generating, this gonna be the way to go.
daniel wrote:ah, i understand :)
Could you send me an email or PM, i would like to send you a test version...
Arvind
Post by Arvind »
Is this thumb size option implemented in higher versions of nConvert?
If yes, how do you use it?
Could you explain with an example?
Thanks
arvind
