avi thumbnail in asp
SyntaxError
Post by SyntaxError »
I cannot display any avi file with loadbitmap command in an asp page. I have checked if proper codec was installed (techsmith, etc...) and even for normal avi file it does not work : it says :
GflAx.GflAx.1 error '80004005'
Unknown format
/image.asp, line 25
Any help or hint ?
Thanks, this tool is just great!
David
Re: avi thumbnail in asp
SyntaxError wrote:I cannot display any avi file with loadbitmap command in an asp page. I have checked if proper codec was installed (techsmith, etc...) and even for normal avi file it does not work : it says :
Unknown format
/image.asp, line 25
Any help or hint ?
GFLAx can not load movie files
JustCJ
Post by JustCJ »
Has the ability to load movies with GFLAx been added yet by any chance?
If not, are there any plans to add it in the future? Thanks!
- CJ
Rille
Post by Rille »
Movie support would be nice plz add it
Rille wrote:Movie support would be nice plz add it
But what do you want? Function to extract a frame from a movie, for example?
lazerfisk
Yahoo Messenger: lazerfisk
Post by lazerfisk »
That sounds like a good idea. It could use the page property to load a specificed frame on demand, that way it wouldn't have to load the entire clip. I'm sure this would be a really useful feature :)
Cheers,
Christopher
Rille
Post by Rille »
yes plz :D
