Best way to display thumbnail in asp page
SyntaxError
Post by SyntaxError »
I just wonder what is the best way to display a thumbnail as an <IMG tag in a web page. I currently use the LoadBitpmap with a resize function, but I have seen some thumbnails functions in the help. Would they be better ?What are they for ? Do you have any examples...
Thanks for your help Pierre, this software is really good.
David
Re: Best way to display thumbnail in asp page
SyntaxError wrote:I just wonder what is the best way to display a thumbnail as an <IMG tag in a web page. I currently use the LoadBitpmap with a resize function, but I have seen some thumbnails functions in the help. Would they be better ?What are they for ? Do you have any examples...
LoadThumbnail is sometimes faster than LoadBitmap+Resize
SyntaxError
Example for white background with CanvasResize
Ok I use now LoadThumbnail, but :
I try to change background thumbnail with GFlax to white but it does not work :
.LoadThumbnail File, Px, Px
.ResizeCanvas Px, Px, RGB (255,255,255)
Could you give one example?
Cheers
David
