Tree pane collaps
Tree pane collaps
Post by Guest »
The Tree Pane in left side collaps to af small width every time I reopen XnView 1.90 (v.4.75), so I cannot see the contents.
I must draw it to a readable width every time
Regards
Kurt L.
Denmark[/img]
zencd
Post by zencd »
Cannot reproduce (v1.90, win xp sp2)
The tree panel occupies the same place it was last time
Reinstall 1.90
Post by Guest »
Now it works.
Installed 1.90 as update to 1.84.
Have now uninstalled all, af reinstalled 1.90 as new, and then no problems.
Regards
Kurt L.
Denmark
Killua
Post by Killua »
zencd wrote:Cannot reproduce (v1.90, win xp sp2)
Well, but I can reproduce (v1.90 zip version, win xp sp2)...
And I tried to del the key in registry,but not work...
Do you have cleaned old registry settings? And xnview.ini?
Re: Reinstall 1.90
Anonymous wrote:Now it works.
Do you have the old .ini?
