1.90:No anti-aliasing filtering fullscreen
RazR
Post by RazR »
As I installed version 1.90 I noticed that XnView does no anti-aliasing filtering of the fullscreen pictures (1600x1200) always when I double clicking on a picture (settings on double click are "View, Edit and FullScreen"). Then (on a fullscreen) anti-aliasing works, but only if I zooming this picture (either "+" or "-") or if I go to next picture in a fullscreen mode.
In version 1.82 - all work as it is necessary: double click on a picture -> View -> Edit -> FullScreen (anti-aliasing works immediately)
As this possible correct in 1.90?.. Thx :)
Pierre's working on a maintenance release v1.90.1, and I'm confident that this will be fixed by then.
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?t=11696]RC3: Fullscreen HQ starts after pressing F12.[/url]) wrote:
bravd wrote:in browser mode open an image (go to view mode), next go to fullscreen...an image will be displayed in low quality...
...then, when I go next image and go back again, the same image will be displayed good now (HQ)...also pressing F12 (options), then press 'ok' causes display image in HQ...all next images are displaying in HQ...
As marsh said, problem occurs when first looking at an image...remember also, this problem doesn't exist when you go to fullscreen directly from browser mode...when you open an image in fullscreen from view mode there is the problem...
Ok, now i have it :-)
