a) Suggestion:
The funktion "Image > Rotate > De-Skew..." should obey the background colour information of the "Image > Rotate > Custom" funktion.
a) Present state:
The background colour for "Image > Rotate > De-Skew..." is always black and there is no possibility to change it.
b) Suggestion:
The funktion "Image > Rotate > De-Skew..." should leave binary (black/white) pictures as they are = in binary.
b) Present state:
The funktion "Image > Rotate > De-Skew..." changes binary (black/white) pictures to 256 bit gray scale.
dirk
Image > Rotate > De-Skew --> set background colour
x73
Re: Image > Rotate > De-Skew --> set background col
Rightx73 wrote:a) Suggestion:
a) Present state:
Sometimes smoothing rotate make a better result...b) Suggestion:
b) Present state:
x73
De-Skew (case b)
Concerning case b:
I think, those who want the better result should convert to grey scale themselves before using "De-Skew...".
(But of course this can be seen different - maybe they suggest me to convert to b/w myself after using "De-Skew"...).
Dirk
Dirk
