XnView keeps creating descript.ion files
The Q
Post by The Q »
How do I disable the ability of XnView to create the descript.ion file?
I have no problem with adding it, since it's a feature lots of people want, but I can't seem to find the option to NOT have it be created every time I rename a file in a folder or otherwise alter something.
Many thanks for the BEST viewer and rendering engine out there!!
The Q wrote:How do I disable the ability of XnView to create the descript.ion file?
Ok, a :bugconfirmed:
Thanks
The Q
Post by The Q »
Thanks for the note that it's a bug, I look forward to the next build and I'm glad to have helped in a small way to making it even better!
