slideshow as exe?
slideshow as exe?
Post by Guest »
how can You use the slideshow outside xnview (save)? with what program should i play the .sld file?
is it possible to save the slideshow as an exe file?
Re: slideshow as exe?
Anonymous wrote:how can You use the slideshow outside xnview (save)? with what program should i play the .sld file?
With xnview
Only XnView Deluxe has this feature.
thanks for the swift reply!!! (nt)
Post by Guest »
slideshow on cd
Post by Guest »
is it possible to burn .sld files on cd (nero burning rom) and also putting xnview on this cd, and give this cd to relatives? will this work? Is it "legal" to do so?
Re: slideshow on cd
Anonymous wrote:is it possible to burn .sld files on cd (nero burning rom) and also putting xnview on this cd, and give this cd to relatives? will this work? Is it "legal" to do so?
Yes
ckit
Post by ckit »
Anonymous wrote:is it possible to save the slideshow as an exe file?
IrfanView can do this and is freeware.
Ok, i'll add it the next time to the freeware version :-)
