Difference between Description and Comment?
jimspeiser
Post by jimspeiser »
What is the difference between "Description" and "Comment"? I seem to have the version of XnView that does not discuss this in its documentation. Also, why is there no choice to print descriptions with the pictures? I've just spent an hour typing in descriptions, I hope I haven't wasted my time. :|
==JJS==
Lostclown
Post by Lostclown »
Description is a text that XnView stores in a file called "descript.ion" in the same folder as the image is stored. Comment is a text that is stored within the image file.
So if you move an image file you might loose the description as it could be left behind. But you would not loose the comment as it is a part of the image file that was moved.
Problem is that not all image formats can handle comments.
Regards, Lostclown
Danny
Post by Danny »
IIRC descriptions are stored in seperate "descript.ion" files in the same directory. "Comments" are stored inside the pictures.
Lostclown beat me to it. :)
Copy comment with file
>> Lostclown
:) Hello !
- Hence, it should be nice that the program copies also the comment while it copies / moves the file.
- That exists i.e. in Total Commander (as an option) :
* When you copy a file which has a comment in the <descript.ion> file of the original folder where it's located, another <descript.ion> is created in the target-folder (with the comment of that file as content) if none exists.
* Whether the target folder contains already a <descript.ion> file, the comment of the copied / moved file is simply added into that existing <descript.ion>.
:mrgreen: Kind regards,
Re: Copy comment with file
Clo wrote:* When you copy a file which has a comment in the <descript.ion> file of the original folder where it's located, another <descript.ion> is created in the target-folder (with the comment of that file as content) if none exists.
1.74 has already this feature.
Hi Pierre !
- Right, it works, but I didn't find it in the "What's new"...
:mrgreen: regards, Claude
Post by Guest »
Fantastic updating, Pierre. Thank you very much!
I would suggest two more tools: 1) the possibility to copy the descript.ion file automatically when copying the jpg file; 2) the possibility to search for an/more image/s by searching IPTC keyword(s).
Thank you again!
Paolo
