I installed v2.66 on my server, and found that activating the filters (like gflax.sharpen and .enhancedetails) crash the .dll during execution. All I get is the ASP 0115 error, something about a trappable error in external application; script cannot continue.
When I tried going back to v2.54 the behavior continued.
Any ideas?
Gflax 2.66 problem
Re: Gflax 2.66 problem
On which picture?b.e.wilson wrote:I installed v2.66 on my server, and found that activating the filters (like gflax.sharpen and .enhancedetails) crash the .dll during execution. All I get is the ASP 0115 error, something about a trappable error in external application; script cannot continue.
Any ideas?
b.e.wilson
I have many 45 mpixel images that I process for presentation on the web They all behave this way. Here is an example: http://herbarium.uvsc.edu/virtual/viewe ... 3390s1.jpg (only the main image gets sharpened, and currently sharpening is disabled).
There is a link for downloading the raw image if you like, on the right-hand side.
Edit:
I should also say I am cropping then resizing the image first.
Here's the code. I've commented the sharpen line out for now.
When the sharpen line is uncommented, here's the error:
Second edit:
When I create an image from scratch, I can use the .sharpen and other filters without creating the error.
Edit:
set GflAx = Server.CreateObject("GflAx.GflAx")
GflAx.LoadBitmap sImageFolder&request.querystring("f") 'f=relative path to the file
x = request.querystring("x") 'OriginX, the top left corner of the section of
'the image to be viewed.
y = request.querystring("y")
w = clng(request.querystring("w")) 'WindowWidth, the width of the crop
h = clng(Request.querystring("h")) 'long variable needed for the if-then
dh = request.querystring("dh") 'DisplayHeight
dw = request.querystring("dw")
fw = GflAx.width 'full image width
fh = GflAx.height
m = fw/w 'magnification factor
s=30 'sharpening factor
if m>150 then s=35
if m>300 then s=50
'don't crop if the entire image is requested:
if (w<fw) OR (h<fh) then GflAx.Crop x, y, w, h
GflAx.Resize dw, dh
'GflAx.Sharpen s
c = request.querystring("c") 'name of copyright holder
'c = c &" "&gflax.about
if c<>"" then
With GflAx
.FontSize = 16
.FontName = "Georgia"
.FontBold = True
.FontItalic = FALSE
.TextOut c, 15, dh-25, cWhite
.TextOut c, 14, dh-26, RGB(0, 64, 0)
end With
end if
GflAx.SaveKeepMetadata = True
GflAx.SaveFormat = 1 '1=JPEG, 2=GIF, 3=PNG, 4=BMP, 5=TIFF
GflAx.SaveJPEGProgressive = True
GflAx.SaveJPEGQuality = 85 'this can be raised to 100 for better image quality
'at the expense of bandwidth
Response.ContentType = "image/jpeg"
Response.BinaryWrite GflAx.SendBinary
set GflAx = nothing
Active Server Pages error 'ASP 0115'
Unexpected error
/virtual/sheet.asp
A trappable error (C0000005) occurred in an external object. The script cannot continue running.
b.e.wilson
