An asm grogram using GFL
Grincheux
Post by Grincheux »
Here is a small program I have written to test GFL with asm language.
Sources files : http://www.stosd.com/telecharger/IVSrc.exe
Program : http://www.stosd.com/telecharger/IVBin.exe
You have to setup windows registry by loading the I-View.reg files
The IVSrc.exe file contains the GFL interface for MASM
By default the program loads the French interface.
For English interface you have to modify the [Default] key
and sets the Language item to 2.
This programs runs under GFL2.54.
Kenavo.
