1.9: Crash when batch renaming folders
ckv
Post by ckv »
XnView crashes when I try to batch rename folders. The batch rename usually works with about 50 folders, but if I try to rename more folders at once XnView most likely crashes. The crash occurs before the batch rename dialog is even shown.
