hi,
On loading the Nero plugin, (Tools >> Plugin >> CD (Nero), I am getting the non-english version.
After some research, I found out that if I rename / Delete the file, neroCD.ing, one of the two constituent files of the downloaded plugin (Nero.zip), I am getting the English version with the window titled "Nero Burning ... ".
By this, I understand, that If one wants the English version, the file neroCD.ing may have to be deleted. I request that this may be confirmed.
By the way, the window says "To be able to write animation, you must have the Nero MPEG2 encoder". Can someone please elabourate this?
Thanks in advance for the responses. Thanks for the great experience with XnView.
murthymsr
CD (Nero) Plugin : how to get the English version?
Re: CD (Nero) Plugin : how to get the English version?
Please try the 1.90.2, i've fix itguest - murthymsr wrote:hi,
And for mpeg2, it's on nero webpage...
guest - murthymsr
I found the problem solved in 1.90.2 Thanks.Please try the 1.90.2, i've fix it
mpeg2 plugin for nero appears to be a payware. I wish we had a plugin for some good and free CD burner program like cdburnerxppro or deep burner though !
murthymsr
