Export dialog bug in 1.90.2
foxyshadis
Just noticed this, when you change a setting in the export dialog, the location of the second image is reset to 0,0, but dragging the first slightly will make it jump back.
Re: Export dialog bug in 1.90.2
Ok, i'll fix itfoxyshadis wrote:Just noticed this, when you change a setting in the export dialog, the location of the second image is reset to 0,0, but dragging the first slightly will make it jump back.
