1.90.2 full screen & taskbar
Anne
Post by Anne »
Hi, i always start Xnview on full screen mode and i've found a little problem on v1.90.2 :
- Start Xnview on full screen mode from Total Commander.
- Picture is showed ok on full screen mode.
- After 1 second taskbar is showed on the screen.
- Taskbar dissapears automatically after 0,5 seconds.
Only happens on v1.90.2, i've downgraded to v1.90 and problem dissapeared.
Thanks for such great program. :D
Anne
Post by Anne »
I forgot to mention that i use Xp-SP2 and that taskbar showed is windows taskbar.
Thanks.
Re: 1.90.2 full screen & taskbar
But with 1.90 some users had the taskbar not hidden, i'll check
Do you start in edit fullscreen or browser fullscreen?
Anne
Post by Anne »
Hi, my windows taskbar is always hidden.
I'm sorry but i don't understand very well the difference between these two modes, i'll try to explain you what i do :
I've configured Total Commander (F3) to show all pictures with Xnview.
The picture is showed directly in absolutely full screen mode without title bar, menus, toolbar, statusbar, etc.
Thx.
Anne
Post by Anne »
Hi, i've opened the picture with Xnview (without using Total Commander) and exactly the same problem appears when on absolutely full screen mode (without title bar, menus, toolbar, statusbar, etc).
Thanks again.
Which setting do you have in Option/Geenral/Mode when starting...?
Post by Guest »
Mode when starting with a file = Fullscreen-Edit
Someone with the same problem??
Anne
Post by Anne »
I've installed Xnview on another computer (fresh instalation, without importing my ini files) and i've the same problem.
Both Pc with Xp-Sp2 & Nvidia cards.
I've you want i can try to make a video and upload it to my ftp site.
Thx.
Could you send me a PM with an email, i would like to send you a test version
anne
Post by anne »
xnview wrote: Could you send me a PM with an email, i would like to send you a test version
I've send you a PM with my e-mail, and for the reason that i explain you on the PM i've configured Gmail to not consider messages received from "[email protected]" as spam.
anne
Post by anne »
Problem solved, it works OK now.
Thanks :!:
Thanks :!:
Not really, it's like 1.90, so doesn't works always...
