Then open images from explorer or something else(WinRAR). I open first image then press ESC then click on next image and i wait for about 10 seconds to open. I use multiple instances of xnview in preferences, but not help. Xnview very slow close and cause this bug.
How correct this?
Thank you.
Slow open from explorer
Plugins loading ?
- This could be caused by the plugins loading, if you have the whole plugins…
- Try to move temporarily the useless plugins in any empty directory; you can keep too the minimal amount of plugins, then pack the rest in the Plugin sub-dir, moving the DLLs in the archive (RAR, ZIP… that I do the most time)
SniCKerZ
SniCKerZ
SniCKerz et al,
Pausing the virus scanner is not really an option. Please have a look at Slow starting and quitting (1.70.2 and above), this should help.SniCKerZ wrote:Yes.
I pause him, this help.
Thank you very much.
Dreamer
My Light mode idea could solve this problem too... (I'll add an Automatic light mode soon, too...)
SniCKerZ
Dreamer
Light mode was deleted, I've added Automatic light modeDreamer wrote:My Light mode idea could solve this problem too... (I'll add an Automatic light mode soon, too...)
I've excluded XnView and it's subdirectories from scanning in McAfee VirusScan, but this did not help. The one and only thing that helped was using the Windows registry. I'd be interested to know which virusscanner and version you are using and whether excluding helps in your case.SniCKerZ wrote:Thank you!
I just add xnview to exclude list.
@Dreamer: I think light mode or automatic light mode might speed up things a bit, but here we are talking about a 10 second start-up time. 10 seconds is not just slow, it's unacceptable and a bug.
SniCKerZ
2helmut
I use Russian AV DrWeb www.drweb.com if you interest. I add %programfiles%\xnview works fine.
My settings store in %programfiles%\xnview\xnview.ini
SniCKerZ
