I like the Favourites thing. I added the folders I use.
But I actually forget it exists because everytime when I start Xnview, I see the Folders view and I am used to search the folders I need, wich is an annoying time consuming task. Then I realize, if I just click favourites I have them all.
Would be nice if it could be set to start with Favourites instead of Folders, and if this could be set in the INI so it can be done for All Users.
Open With Favourites, by default (set in xnview.ini)
ZileXa
Re: Open With Favourites, by default (set in xnview.ini)
Right, perhaps a good optionZileXa wrote:I like the Favourites thing. I added the folders I use.
