with XnView presently we are able to send by mail original / resized & jpeg converted pictures using the default mail client.
I wish the program also has the facility to send the contact sheet by email by adding email button in the contact sheet configuration window.
And why not we have the facility to send also all the other products like zipped pictures, slide show & web page etc. ?
Thanks in advance for your attention.
Facility to send by email all the available products
murthy363
- Yahoo Messenger: murthymsr
I am a lazy person, always searching for ways to avoid work and still manage the show !
My System : Win XP SP2 + XnView standard English version
Re: Facility to send by email all the available products
But for a created contact sheet, you can send it by email????murthy363 wrote:with XnView presently we are able to send by mail original / resized & jpeg converted pictures using the default mail client.
murthy363
Yes, I can send now a created and saved contact sheet by email by selecting the saved contact sheet and pressing the Tools >> Mail for opening the email window.But for a created contact sheet, you can send it by email????
But what I wish is that I can create and send the contact sheet directly without saving to disk. This may be achieved by adding an additional email button to the contact sheet configuration window, which will open up the email client directly with pre-loaded subject and body text. This will make the job through with minimum operations.
And I may also have the facility to send multi-line (may be three line) body text by restoring saved INI settings say mailbody1, mailbody2 and mailbody3 or some thing like that.
Thanks for your quick and positive response as always.
No you can without saving it, when you have the contact sheet, use Tools/email, don't save it before...murthy363 wrote:Yes, I can send now a created and saved contact sheet by email by selecting the saved contact sheet and pressing the Tools >> Mail for opening the email window.But for a created contact sheet, you can send it by email????
murthy363
Thanks Pierre, the program creates .dat file and I am able to send by email.No you can without saving it, when you have the contact sheet, use Tools/email, don't save it before...
The dat file was openable with XnView only.
This 'suggestion' has finally turned out to be a support request. Sorry for that. May be I have to familiarize with the program more before I post a suggestion.
Thanks again for your fast response.
