'Add subfolders to cache' in context menu
In XnView 1.90 the user can add a folder and all it's contents, using Tools > Options > Browser > Thumbnails > Cache, button "Add folder..".
I think it would be intuitive and convenient way if the user would have "Add subfolders to cache" in the context menu in the folder tree.
Note: This suggestions is derived from a mail from M. Digel.
Danny
Post by Danny »
I don't think so. The cache is more like a convenience and not a prominent feature. It should stay in the back.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
SimesB
Post by SimesB »
Hi there Helmut,
I don't think that would have much benefit as you might as well just double click on the folder to open it and the thumbnails would load into the cache.
A much better option would be to be able to do this for all subfolders without loading them all into memory at the same time. I don't know if this is possible - have it so that it would move through all the subfolders adding the thumbnails into the cache, when one subfolder has finished move on the next subfolder. The reason I say this is that I have folders with huge amounts (50 gig+) of stock images and it's not practical to use the 'View>show images in subfolders' option because smoke comes out of my pc when I try that :wink:
So in other words to automate a way of clicking on subfolder, waiting for thumbnails to load, click on next subfolder, wait for thumbnails to load, click on next subfolder ... etc.
I hope I make sense!
Simon.
SimesB wrote:I don't think that would have much benefit as you might as well just double click on the folder to open it and the thumbnails would load into the cache.
That really would make no sense. The option I mean is "Add subfolders to cache", not "Add folder to cache".
SimesB wrote:A much better option would be to be able to do this for all subfolders without loading them all into memory at the same time.
In XnView 1.90 you can pre"feed" the cache using "Tools > Options > Browser > Thumbnails > Tab > "Add folder". Is this what you mean?
Danny wrote:I don't think so. The cache is more like a convenience and not a prominent feature. It should stay in the back.
Right. Caching is indeed a technical thing and users should not have to care about it. Currently the manual cache feeding is a bit hidden, this is why this idea came to my mind. I would find it very convenient and intuitive but it would indeed spoil the user interface a bit.
