Big huge images
Max2007
Big huge images
Post by Max2007 »
I'm having trouble with viewing very big images. For example this one:
http://marsrovers.jpl.nasa.gov/gallery/ ... abeled.jpg
The image is 15Mb, and instead of opening it, xnview goes crazy, requesting more and more memory, like 300Mb, 400Mb... so I have to kill the xnvew process in Task Manager.
Can someone download this image and try it? Is it my computer or xnview bug?
P.S. XnView 1.90, WinXP SP2.
Re: Big huge images
Max2007 wrote:I'm having trouble with viewing very big images. For example this one:
Have no problem to load it, but perhaps a problem with the high zoom quality. Try to disable option/View/reduce
Max2007
Re: Big huge images
Post by Max2007 »
xnview wrote:Try to disable option/View/reduce
That helped, thanks!
Ploughman
Post by Ploughman »
Same problem here
Example:
www.lovepixel.idv.tw/
I have whole image 10k x 10k
I can view it in gif or png easily, but not in jpg.. I know that jpg is not suited for that kind of graphic, but still i'd like to view this picture in jpg :)
There is no difference.. 99% cpu usage and rising memory consumption..
P.S. Xnview still load pictures faster without cache options turned on..
system:
XNView 1.90.2
WinXP SP2
athlon 64 3200+
nforce 4 ultra
512mb ram
Radeon x1800 gto
Ploughman wrote:Same problem here
Example:
system:
XNView 1.90.2
WinXP SP2
athlon 64 3200+
nforce 4 ultra
512mb ram
Radeon x1800 gto
Is it possible to send me it in jpeg?
Ploughman
Post by Ploughman »
Now all work fine, i guess it was just a glitch in a system due to small size of windows swap-file.. I've just increased it from 512mb to 1024mb.
Thanks!
