Problem with file.RAF 1.90.02
Motion
Post by Motion »
Say hello at all the forum, excuse for my English, but stò using a software translator.
Have installed from little the new version 1.90.2 (but on PC have still installed the old version 1.80.0.0) have problems to open the .raf file of Fuji, that is to open them he uses also 4-6 second, then see them well and can modify themselves quietly.
With vesione 1.80 instead to open them it was very fast, on what it can depend?
I have searched on the forum but I have not found answers.
Thank you
Re: Problem with file.RAF 1.90.02
Motion wrote:Say hello at all the forum, excuse for my English, but stò using a software translator.
Thank you
Check the View/Misc/Camera RAW setting
Motion
Post by Motion »
xnview wrote: Check the View/Misc/Camera RAW setting
Thanks for the answer. :wink:
I have modified, as suggested by you options "View/Misc/Camera RAW setting", in the menu and I have set up it up "Half size", and it is actually lightly more fast, but the not fast end as for the version 1.80.0
I understand that they are file also 14.2 MBs heavy, but what I could do to make the flowing fast between the various file?
At times I have hundreds of file to run, and lose 2-3 secs for everybody, it is not max..
Please send me you r email by PM to send you a test version...
