An exception occurred: 'LoadBitmap'
nec
Post by nec »
When i try to load a .jpg file in ASP with: .LoadBitmap sFile
I get this error message: An exception occurred: 'LoadBitmap'
The object is set with Set ctrl = server.createobject("GflAx.GflAx") and did work fine until recently.
I have no idea why, but i need it fixed.
Any suggestions?
nec
Post by nec »
The call worked after a IISRESET, but its kinda scary that it came up at all...
Does anyone know what it was?
nec wrote:The call worked after a IISRESET, but its kinda scary that it came up at all...
Could you send me the picture that you load?
nec
Post by nec »
It was a whole bunch of pictures,
They work now, but im still curious of why this happened.
nec
Post by nec »
Hmm, now it happened again.
I have no idea whu.
Works after a IISRESET.
Please help me out.
nec wrote:Hmm, now it happened again.
I have no idea whu.
Could you show me more about your script?
nec
Post by nec »
This is a function called AFTER a ranomization is done, with a global array called aBefore, and aUsers wich includes SID's (relevant to the path). The function returns x amount of linked pictures (with javascript calls) and checks that the picture isnt already loaded.
function getRandomizedPicture(nTime)
	on error resume next
	dim i
	dim bBefore
	dim fs
	dim objFile
	dim sFilePath
	dim ctrl
	Set fs=Server.CreateObject("Scripting.FileSystemObject")
	bBefore = 0
	nActiveSID = Int(Rnd*ubound(aUsers,2))
	sPicture = aUsers(1,nActiveSID)
	for i = 0 to ubound(aBefore)
		if nActiveSID = aBefore(i) then
			nTime = i
		end if
	next
	if instr(lcase(sPicture), ".jpg") > 0 then
		sPath = left(sPicture, instrrev(sPicture, "/"))
		sPicture = right(sPicture, len(sPicture)-instrrev(sPicture, "/"))
		sPicture = sPath & "_thumb_" & sPicture
		sFilePath = replace(sPicture, "/", "\")
		sFilePath = "C:\Inetpub\GenerationV\root" & sFilePath
		if fs.FileExists(sFilePath) = true then
			with ctrl
			.LoadBitmap sFilePath
			nWidth = nWidth + .Width + 4
			if nWidth < 560 then
				aBefore(nTime) = nActiveSID
				getRandomizedPicture = "<a href=""javascript:parent.loadintoIframe('contens','" & sOthersLink & "&SID=" & aUsers(0,nActiveSID) & "')""><img src=""" & sPicture & """ height=""59"" border=""0"" class=""border"" hspace=""2"" vspace=""2""></a>"
			else
				exit function
			end if
			end with
		else
			getRandomizedPicture = getRandomizedPicture(nTime)
		end if
	else
	end if
	Set fs= nothing
	set ctrl=nothing
	on error goto 0
end function
The error has accured once more since my last post. Again the IISRESET solved the problem temporary.
Please help!
nec wrote:This is a function called AFTER a ranomization is done, with a global array called aBefore, and aUsers wich includes SID's (relevant to the path). The function returns x amount of linked pictures (with javascript calls) and checks that the picture isnt already loaded.
Please help!
Strange, you have only a LoadBitmap??? Which version do you use? The error occurs after x .LoadBitmap?
nec
Post by nec »
No, the error is called WHEN the .LoadBitmap sFilePath is executed.
The other call to the ctrl object is the nWidth = nWidth + .Width + 4 call. The function returns a HTML string of pictures that all together doesnt exeed 560px width. It also checks that the active picture isnt already included.
nec wrote:No, the error is called WHEN the .LoadBitmap sFilePath is executed.
Do you use the last version?
nec
Post by nec »
No, i had the 2.01 version installed.
I've updated it.
I'll be back if i run into further problems.
Thanks for the help.
Post by Guest »
I'm still experiencing the same problem.
Once a day or something the component seems to crash the IIS aswell.
Maybe i should tell you that i use the code above on the start page of the web - and that the .width param is accessed 20 times each time a user logs on. Could there be some kinda memory problem?
nec
Post by nec »
that was nec of course.
Anonymous wrote:I'm still experiencing the same problem.
.Width is only a property, LoadBitmap occurs only one time. Do you use now the last v2.20?
nec
Post by nec »
Yes.
Now it hung again - with the errormessage above...
