plugin problem
plugin problem
Sometimes, when i apply the adobe plugins, the right of the image gets erased to black. Also, when i am running the plugin window, before it erases the part of the image, the preiview gets pink lines accross it if i zoom out to far. What should i do?
Re: plugin problem
With which plugin?Anonymous wrote:Sometimes, when i apply the adobe plugins, the right of the image gets erased to black. Also, when i am running the plugin window, before it erases the part of the image, the preiview gets pink lines accross it if i zoom out to far. What should i do?
