I just upgraded to 1.90.2. The behavior mentioned in the title seems to have changed from 1.80.4.
When 'Fit Window to Image' is selected and you move to the next image, the next image is always centered in the display.
In previous versions, I could select 'reset x/y' and start at the top left of the image. I don't see a way to get this behavior back in 1.90.2.
Thanks.
Fit Window to Image and Reset X/Y incompatible?
Re: Fit Window to Image and Reset X/Y incompatible?
Do you use 'Force Xnview to fit' too?mfeingol wrote:I just upgraded to 1.90.2. The behavior mentioned in the title seems to have changed from 1.80.4.
kuma
I'm using 'Fit window to image' and 'Force Xnview to fit' checked. I also curious to see 'reset x/y' is disabled.xnview wrote:Do you use 'Force Xnview to fit' too?mfeingol wrote:I just upgraded to 1.90.2. The behavior mentioned in the title seems to have changed from 1.80.4.
Besides the problem as mfeingol mentioned, Xnview doesn't maintain the position of window, and always be centered on screen. I can hardly imagine a logical reason. Please let me know why it is or it's just not-yet-featured.
Ok, i'll fix itkuma wrote:I'm using 'Fit window to image' and 'Force Xnview to fit' checked. I also curious to see 'reset x/y' is disabled.xnview wrote:Do you use 'Force Xnview to fit' too?mfeingol wrote:I just upgraded to 1.90.2. The behavior mentioned in the title seems to have changed from 1.80.4.
Please send me you .iniBesides the problem as mfeingol mentioned, Xnview doesn't maintain the position of window, and always be centered on screen. I can hardly imagine a logical reason. Please let me know why it is or it's just not-yet-featured.
mfeingol
To answer your question, that setting is irrelevant. The unexpected behavior with the y coordinate happened regardless, since the 'reset x/y' setting was disabled.xnview wrote:Do you use 'Force Xnview to fit' too?
