I'd like to ask you, what's the new categories pane good for. I tried for hours to find out how to use it, but I couldn't find any solution. Could somebody give me any help? I'm quite advanced PC user, but I'm somehow stuck with this feature.
I suppose I need to create a database of images, but I can't find such option in the menus.
Categories
marsh
Drag & drop filename
Using left mouse button, drag and drop filename onto a category.
vlada
The problem is, that I can't drop file(s) onto a category. If I create one, I can't rename or delete it and I can't drop files there. I can drop files to rating and labels, but then again nothing happens.
You might want to have a look at this movie (flash, 7-zip compressed). It shows how it works on my computer.
I'm probably missing something, but I can't find out what am I doing wrong.
Strange, could you try to set Xnview folder for Option/Integration?? Perhaps a problem with 'Application data' foldervlada wrote:The problem is, that I can't drop file(s) onto a category. If I create one, I can't rename or delete it and I can't drop files there. I can drop files to rating and labels, but then again nothing happens.
