Effects input fields
shkin
I'm not sure that it is a bug, but why are effects input fields all greyed out? It is only possible to adjust the values using the slider and the arrows, while everywhere else the fields can be adjusted directly.
Re: Effects input fields
Yes, right not really a bugshkin wrote:I'm not sure that it is a bug, but why are effects input fields all greyed out? It is only possible to adjust the values using the slider and the arrows, while everywhere else the fields can be adjusted directly.
shkin
Thanks for the reply.xnview wrote:Yes, right not really a bugshkin wrote:I'm not sure that it is a bug, but why are effects input fields all greyed out? It is only possible to adjust the values using the slider and the arrows, while everywhere else the fields can be adjusted directly.
Is there a chance it would be changed to the editable field? It would be great.
