1.90.2 - Mouse pointer & Full screen-Edit
anne
Post by anne »
Hi, i'm not absolutely sure that this is a bug, but i think so.
- Xnview 1.90.2   //  Xp Sp2
- Start Xnview in Fullscreen-Edit, mouse pointer is hidden.
- If you press delete key on keyboard a dialog pops up asking for a confirmation for delete the file, you click with mouse on Yes button to confirm delete and mouse pointer is hidden automatically after 4 seconds (Ok).
- But if you press delete key on next picture and instead of using mouse to click on Yes button, you press Enter key on keyboard then picture is deleted but mouse pointer is not automatically hidden after 4 seconds (Bug).
Maybe it could be a good idea to add an entry on Xnview.ini, to do not show mouse pointer under any circumstance in Fullscreen-Edit while mouse is not used by the user.
Thanks :!: .
Re: 1.90.2 - Mouse pointer & Full screen-Edit
Thanks :!: .
Right, and if you move a little the mouse, the pointer will be hidden...
anne
Post by anne »
xnview wrote: Right, and if you move a little the mouse, the pointer will be hidden...
Hi :), i know that option, but sometimes i have to delete many photos and i prefer to do it in Fullscreen-Edit mode and only using keyboard, but if i have to move the mouse each time that i delete a photo to hide mouse pointer ... :(
I think that maybe the best solution (for keyboard addicts like me :wink: ) could be to add an optional entry on Xnview.ini to only show the mouse pointer on Fullscreen-Edit mode when user use the mouse, or at least to automatically hide the pointer without having to move the mouse.
Thank you very much :!:
anne
Post by anne »
It works ok on v1.90.3, thank you :D .
