Program won't go into my subdirectories
Aminal
I have my pics in my doccuments\prefered customer\application data\newsbin\downloads and then in individual folders. The program won't even let me get into application data not alone the other folders which are buried deeper. any ideas? thank you
Re: Program won't go into my subdirectories
You see your folders in tree, and you can't select it??Aminal wrote:I have my pics in my doccuments\prefered customer\application data\newsbin\downloads and then in individual folders. The program won't even let me get into application data not alone the other folders which are buried deeper. any ideas? thank you
foxyshadis
By default, application data is hidden, maybe you need to check "show hidden files and folders" in options->file list->misc. (It doesn't follow the windows explorer setting, which would be neat.) Or just unhide the folder, like I do, since I don't want to see stuff I've hidden.
Alternately, you can just paste its full path in the address bar and make it a favorite.
