First of all, my thanks to the author for a great picture viewer. Yet, I have some suggestions.
Sometimes I need to view many photos in a sequence (or randomly) without breaking down the existing folder hierarchy. Is it possible in XnView to do so?
Also, I don't think the way pictures are enlarged is satisfactory.
I can see jagged square pixels instead of smooth interpolation of some kind.
This is a bit sad for such an advanced and stylish program as XnView.
Recursive slideshow
foxyshadis
Re: Recursive slideshow
There are two options that control this:Vortex wrote:Also, I don't think the way pictures are enlarged is satisfactory.
Options->View->High Quality Zoom
Both should be checked, and I believe they are by default; this is browsing normally.
Slide Show->More Options->Use High Quality
This is probably unchecked by default, and it controls that same behavior in the slide show.
For the other problem, I might suggest adding them all into a custom category. You can put pictures from anywhere into it, and then view it and easily start a slide show of everything in it.
