1.90.2 Focus Stealing from TC
kustodian
I'm using WinXP SP2, XnView 1.90.2 and I have configured XnView to open in full screen.
I use Total Commander. When I press enter on a picture to open it XnView opens the picture in full screen, then I press ESC to close XnView, and than Total Commander doesn't have focus, so I have to click on it or press ALT+TAB.
This never happened before and it is very annoying.
Re: 1.90.2 Focus Stealing from TC
With 1.82.4?kustodian wrote:I'm using WinXP SP2, XnView 1.90.2 and I have configured XnView to open in full screen.
Not for me
—> kustodian
Hello !
• This doesn't occur for me, neither using TC 6.56, nor TC 7.0 ß3x.
• Following your steps, I get TC again directly, no problem…
• Same starting in normal “View” mode instead of “Full screen”…
• With XnView 1.90.x
KR
I just noticed that when "Mode When Starting With a File" is:
1. "Fullscreen - Edit", TC looses focus,
2. "Normal", and than I press ENTER to switch to fullscreen, then ESC to exit, TC looses focus
3. "Fullscreen - Browser", TC doesn't loose focus, but I want XnView to start in "Fullscreen - Edit".
Here is my config if you want to test with it.
With 1.82.4 everything works great.
kustodian
Honza
have same problem with focus loosing
And my brother described it on both of his computers also!
We use XnView to open pictures in full screen mode. And sometimes after image opening focus mismatch occurs... it's annoying. But we're not 100% sure it is made by XnView... In such case i'm very sorry, but it seems like that.
Just look at it, thanks, Pierre.
Bye.
Bye.
foxyshadis
Honza
Honza
It has nothing to do with TC. Just set up XnView to primarily open pictures in full screen mode. Than open file via TC or Windows Explorer. Escape it... Than fucus start do behave strange and windows don't overlap.
Pierre send me an e-mail i can try tommorow to describe it more precisely.
Jan Brychta
jan/at/brychta/dot/info
Jan Brychta
Here:Honza wrote:It has nothing to do with TC. Just set up XnView to primarily open pictures in full screen mode. Than open file via TC or Windows Explorer. Escape it... Than fucus start do behave strange and windows don't overlap.
Jan Brychta
