stdin for ppm?
guest_jo
stdin for ppm?
I use an application to create normalmaps on 3D- spherical bodies that outs ppm - format on stdout.
http://www.celestialmatters.org/cm//hos ... 03.shtml#2
Is it possible to convert this directly via stdin into png with nconvert ?
I tried some syntax but I failed with it ...
Maybe you can help me ?
Jörg
Jörg
Re: stdin for ppm?
Do you have tried stdin as input file?guest_jo wrote:Hello,
guest_jo
stdin
Yes I tried:
nms 6718.14 4096 20 < srtm_ramp2.world.4096x2048.bin | nconvert -out png stdin
the first tool gives a .ppm-file on stdout but stdin can`t find it.
The author of the normalmap-tool also failed with this (fridgers column,link above), so I thought I ask if nconvert supports stdin at all. But from your answer I suppose it should, so maybe I should contact the author of nms again if he wants to do further efforts...
Can you confirm if my syntax I posted is correct ?
Jörg
Jörg
Re: stdin
Yes, the syntax is true, but could you send me the ppm to test?guest_jo wrote:Yes I tried:
sent !
Hi Pierre,
I wanted to send you the 4096x2028 ppm-file but it is too big for me to send.
I made a version 2048x1024 and zipped it with 7zip and if thats not ok I also made a ppm with 1024x512
Both sent files I can´t get them into nconvert via stdin.
I also tried another syntax cause I had the feeling I would need a specific output-filename but this also failed for both example-files:
nms 6378.140 4096 20.0 < srtm_ramp2.world4k.bin | nconvert -o srtm_ramp2.world4k.png stdin
Maybe you can find out something...
Many thanks for spending your time.
Jörg
Jörg
guest_jo
new test with gzip for stdin
Hi Pierre, to make this issue independent from the quite unknown nms-tools I did the same test with gzip as generator for stdout:
1.) gzip -dc srtm_ramp2.world4k.bin.gz | nms 6378.140 4096 20.0 > srtm_ramp2.world4k.ppm
2.) gzip -dc srtm_ramp2.world4k.ppm.gz | nconvert -out png stdin
The first line is only to test stdout from gzip. It works good and at the end of the pipe the ppm is generated and ok.
The second line I made a gzipped ppm-file and wanted to hand it over to nconvert. I didn´t succeed ! I tried several things: -in ppm ; -o test.png ; -in stdin ; > test.png ; different combinations of it, I give up.
Maybe the test with gzip is better for looking into it.
Jörg
Jörg
Being a longstanding developer and co-author of the 3D space simulation Celestia
http://www.shatters.net/celestia/
I first of all want to express our strong interest in NConvert. As Joerg mentioned above, I have been writing a set of dedicated, cross-platform tools (in C++ ) specialized in generating HUGE planetary textures (~10 GB each
) of highest quality directly from the published scientific data, cutting these into tiles etc.
http://www.celestialmatters.org/cm/index.shtml
http://www.celestialmatters.org/cm/host ... s/nmtools/
Besides my nmtools for normalmap generation, there is now a complementary set, my txtools, that perform analogous tasks for base and specular textures, do high-quality DXT1..3 and notably DXT5nm compression and many other specialized tasks, like mounting RGB + A -> RGBA etc.
NConvert would be a great format conversion tool for us, except it has substantial weaknesses where I need it to be VERY strong
-- I need perfect operation wrto STDIN/STDOUT such that nconvert may be piped together with my other tools.
-- I need optimized dynamic memory management, since we start to work with texture sizes, where other tools hopelessly give up.
-- among the strongest weakness of nconvert is the lack of fast AND high-quality DXT compression for ALL standard flavors, DXT1..3 and notably DXT5nm. The latter being a highly quality optimized DXT5 (RGBA) format specialized to normalmap compression, which has to be of very high smoothness. It was invented by NVIDIA.
As Joerg emphasized already, nconvert only works partially OK with STDIN, also depending on the OS. Take any .ppm RGB texture, for example
and do the simplest possible STDIN action:
nconvert -o test.png stdin < file.ppm
This works in Linux, but NOT under windows XP. In my tools I use the following code to make them work perfectly under STDIN/STDOUT
Also I am told by my OSX-friends that nconvert is quite buggy on MACS...This I can't test myself, but since we always work totally cross-platform, we would need stable performance under MAC-universal (PPC & Intel Macs)
Bye Fridger
#ifdef _WIN32
if (_setmode(_fileno(stdin), _O_BINARY) == -1 )
cerr<<"Binary read mode from STDIN failed\n";
return 1;
if (_setmode(_fileno(stdout), _O_BINARY) == -1 )
cerr<<"Binary write mode via STDOUT failed\n";
return 1;
#endif
Bye Fridger
Tech2000
There is a problem with stdin & nconvert for some formats, it's not possible to write the file before to send it to nconvert??Tech2000 wrote:Unfortunatly this thread doesn't wake any intrests from the developer. To bad since, as Fridger said, this would be of great use for the celestia community too.
Many thinks are possiblexnview wrote:There is a problem with stdin & nconvert for some formats, it's not possible to write the file before to send it to nconvert??Tech2000 wrote:Unfortunatly this thread doesn't wake any intrests from the developer. To bad since, as Fridger said, this would be of great use for the celestia community too.
Yet in Celestia, we are dealing with VERY large sets of image tiles indeed: typically for a 64k x 32k texture of Earth, ~2500 1024 x 1024 pix PNG and or DXT5 or DXT5nm images. That fills O(10 GB) of data for each kind of format. So we are not exactly keen to vaste another 10 GB for intermediate storage.
Since the reaction/interest here was more than "poor"
Bye Fridger
