I'm experiencing a weird bug when XnView starts in Fullscreen-Browser mode. I get the image with the auto size setting I set, but on top of it, aligned to the top-left of the screen, I get a resized version of the image the size it would be in the preview pane. Plus, only the portion of the screen where the duplicate resized image is can be interacted with the mouse.
I tried a couple of different settings, and when I set the auto image size to no fit, I don't get the smaller resized image on top of the original, but the mouse interaction bug is still there.
Everything works fine with the Fullscreen-Edit option.
And if I go from Browser to Fullscreen.
Some more testing tells me the problem is only there when both the tool bar AND tabs are hidden. Unhide one of those and the bug goes away.
Oh, and when both tabs and tool bar are hidden, there seems to be a slight delay in hiding the tool bar when I go from fullscreen to browser, only the first time and when opened in Fullscreen-Browser mode (Fullscreen-Edit is fine).
And since I'm trying some things, I found that going from the Viewer to Fullscreen makes the taskbar pop up for a sec. Same thing happens when opening an image in Fullscreen-Edit mode. And this is no matter what is hidden or not.
Btw, I'm using WinXP.
Hope that helps.
1.90.2 Fullscreen-Browser acting strange
Re: 1.90.2 Fullscreen-Browser acting strange
Make that the Tool Bar AND Tabs AND Status Bar. The duplicate small image problem disapears if one of those three is unhidden.Ismaul wrote:Some more testing tells me the problem is only there when both the tool bar AND tabs are hidden. Unhide one of those and the bug goes away.
