Printing Problem
C
Printing Problem
Post by C »
:bug: When I try to print I get the following error message:
XnView v1.90.2 - [<image>]: xnview.exe - Application Error
The instruction at "0x77805a10" referenced memory at "0x0015f000". The memory could not be "read".
Click on OK to terminate the program
then after clicking OK I get the following message:
The instruction at "0x77fcb8f1" referenced memory at "0xfffffff8". The memory could not be "read".
and the program terminates!
Re: Printing Problem
C wrote::bug: When I try to print I get the following error message:
On which OS? You have always this crash on printing?
C
Post by C »
The operating system is Windows 2000 on an Intel PIII 1000 MHz and 512 MB RAM.
Th previous version of XnView didn't have this problem with such configuations!
C wrote:The operating system is Windows 2000 on an Intel PIII 1000 MHz and 512 MB RAM.
Strange, no problem on win 2K
You print in view mode or browser mode? You have this crash on all files?
Post by Guest »
Sorry for the delay in reply. The problem occurs in both views. And “Yes” it occurs with all the files I’ve tested with (small or large), even the “sample.jpg”! The point is that I didn’t change a thing, the PC, the Windows, or the printer, so I went directly to a bug in the application!
Anonymous wrote:Sorry for the delay in reply. The problem occurs in both views. And “Yes” it occurs with all the files I’ve tested with (small or large), even the “sample.jpg”! The point is that I didn’t change a thing, the PC, the Windows, or the printer, so I went directly to a bug in the application!
The same with 'best fit', 'thumbnail', 'scale', ....?
C
Post by C »
So far, I’ve used the printing button directly! That needs testing…
C wrote:So far, I’ve used the printing button directly! That needs testing…
But what do you use in 'page layout'?
C
Post by C »
When I press Ctrl+P or choose the print button from the File menu, I get the error message. I don’t even get to see the printing screen!
C wrote:When I press Ctrl+P or choose the print button from the File menu, I get the error message. I don’t even get to see the printing screen!
So please contact me by PM or email
Post by Guest »
was this solved? having same problem
Anonymous wrote:was this solved? having same problem
With 1.95.4? Error message before print dialog?
Post by Guest »
Yes, 1.95.4 installed on windows xp sp3. Xnview crashes immediately after clicking on File> Print or the print icon.
Anonymous wrote:Yes, 1.95.4 installed on windows xp sp3. Xnview crashes immediately after clicking on File> Print or the print icon.
Could you send me your email by PM, i would like to send you a test version
irneb
Post by irneb »
Have exactly the same problem on XP SP3 running XnView 1.96.1. As soon as print is started (File-->Print or Ctrl+P) in either the browser view or editor view the crash happens:
XNView - [Elevation 3.jpg]: xnview.exe - Allpication Error
The instruction at "0x77c47366" referenced memory at "0x001d9000". The momory could not be "written".
Then clicking OK gives a similar error:
The instruction at "0x7c911780" referenced memory at "0x00c8d0d4". The momory could not be "read".
Then OK just closes XnView.
Irné
