I frequently change various options to get a real feel of the program.
After some experimentation, I wish to restore to
1) Program defaults (Original XnView.ini file)
2) Last saved desirable set of user defaults
Do we have the facility within the program for at least 1) above?
Thanks in advance for your response.
Restoration to program default options
I am a lazy person, always searching for ways to avoid work and still manage the show !
My System : Win XP SP2 + XnView standard English version
You can rename original configuration file and allow the program to create a new one.
If you want it to use the program folder instead of MS's "user" folders, you can start program with small INI file containing the following info:
[Start]
SavingMode=1
ParamsSavingMode=1
[Cache]
SavingMode=1
I wished that the program may have buttons like 'Save to User defaults', 'Restore from user defaults' Restore from program defaults', like some of the software with LOT of options like XnView has. These buttons may help a layman also.marsh wrote:You can rename original configuration file and allow the program to create a new one.
Thanks for the fast response with a workaround.
