Changing "Auto image size" to "No fit"
SharkD
Post by SharkD »
Changing "Auto image size" to "No fit" causes the "Use transparent index" option to be ignored in View mode.
Re: Changing "Auto image size" to "No fit&quo
SharkD wrote:Changing "Auto image size" to "No fit" causes the "Use transparent index" option to be ignored in View mode.
Really, i can't reproduce it
OK here
:) Hello !
• Same here, it works like it should…
:mrgreen: KR
SharkD
Post by SharkD »
You have to switch images in order for the bug to take affect. You can't simply refresh the image. Also, the bug only affects 32-bit images with transparency.
[edit]
The same problem occurs for me when I zoom in on an image.
